memory loss - rear axle
TrackPack
11:58 AM
Minnesota
So I'm installing new axles with green bearings, rear diff has been apart for over 12 months. Just want to double check on the assembly sequence from the rear housing axle flange - steel shim type gasket, brake backing plate, foam gasket (seen thick paper ones here too) then bearing retainer flange. Am I missing anything?
12yrs! But sounds right...Amazing how quickly ya forget(?)...
Yup, your good to go, if I’m remembering right, lol!
Thanks.
I do have a shop manual.......somewhere.
Your right, just check that the axles go in all the way. With the green bearings, I had to grind a bit off the axle shaft end for the axle to go in all the way.
