Misses under load
moparcanuck
Deceased, But not forgotton
4:38 AM
Ottawa,Ontario
It started running rough when it was cold then it smoothed out as it warmed up. Now it misses all the time but only under load. If I rev it up in neutral it runs great. Suggestions?
Stock 440
Automatic
Six Pack
The last time I had an issue like yours my engine needed a new set of plugs.
Thats sounds like a good ol' fashion American misfire. Sounds like you need a tune up. What ignition? Stock? Aftermarket? Points? Electronic?
I'm sorry, every time I read the title I see Mrs.
Electronic ignition.
Ah yes, Mrs. Underload. I know her well. :toothy10:,
If it misses under light load but will accelerate cleanly when opened up - I have found that to often be a bad set of plug wires. If it starts missing as you are accelerating into the upper rpm range, then I have found that to often be worn distributor bushings. If neither of these fit then it's probably the plugs or distributor cap/rotor. I guess the electronic iginition module is another possibility.
