MOPAR A/B/E BODY CAR MOVING BODY WHEELS SET
Make your own. Hit HF and get some caster wheels, then buy some square metal tubing, flat stock and weld up your very own set.
Make sure and check the weight rating on the casters! (DAMHIK)
I presume you're moving a bare frame/body, no suspension or wheels? If it has wheels...
$65 a pair at HF, and they work pretty good for what they are.
I made my own for far less money than that. Not to difficult if you have a welder.
a little cheaper but comes unpainted. The us car tool set is powder coated.
Made this, has my 74 roadrunner without any suspension or drivetrain on it. Has doors, hood, trunk and fenders though.
Try Graingers, they have a crapload of that kind of stuff
build a set of your own, make it taller too
have a local steel fab or welding shop, cut/bend & weld a few pieces
bring in the leafspring backing plates
& some way to connect to the front of the chassis
You could use bigger pneumatic tires even
better to roll around, be way less then $250+ each set
or the $400-$500+ for set of 2 each
w/4" hard wheels
good luck
w/4" hard wheels
good luck
I've built at least a dozen sets of wheels for assorted projects.... Tried pneumatic tires once.... Unless your paying big $$$ they aren't designed for the weight involved... The tires deform, if you add enough air to support the load the sidewalls fail... Stick with the hard rubber/urethane wheels...
Go visit Pete,he may have a set.If not get him to fabricate a set for you.When making them make them adjustable to raise n lower the car n yes to the hard rubber/urethane.
Thanks for all the suggestions. :thumbsup:
I found these last evening and ordered up a set. The only issue I see is the K-frame mounting holes appear to be small, but that is easily rectified. I'll just hit up the local Harbor Freight & get a cheap set of 8" Chinese wheels.
That's not a bad price at all imo. Like mentioned above, get the solid hard wheels. Get at least 2 that swivel and with a brake. 4 that swivel are real nice for spinning the car around in a circle as well, but can get kind of squirrelly at times.
Yeah. I did the four swivel casters... Once.... You try stuff & see what works best... Then stick with it...
