* Custom, mig welded aluminum 3 piece driveshaft loop setup.
* Machined from 3/8 Inch aluminum barstock and MIG welded
* The construction is 6061-T6 Bright aluminum finish that won't chip or rust and resist corrosion
* Flat barstock is 3/8 Inch and the loop is cut from 5.5 Inch tubing and has 0.25 Inch wall
* Adjust from 6.5 Inches to 21.5 inches in length by using the double bolt holes
* Height adjustment is also variable
$95 plus shipping from SoCalifornia.
