MoPar BB Melling camshaft #SPD-19
Bighead440
4:25 AM
Milledgeville, Georgia
I found an old camshaft, Melling SPD-19, and it is new but has no cam timing card/data. I have a 1992 Melling master catalog and it lists the cam as "discontinued, 1962-1964, 426 Chrysler wedge." Anyone here know if this is a solid lifter Stage III Max Wedge replacement cam? The Street Wedge cam is still available I believe. TIA.
I have an older Melling catalog in storage, I'll see if I can find it
My 80's engine dynamics catalog lists most Melling in cross reference / interchange but not that one
what's your info on the street wedge?
not here either
https://www.melling.com/wp-content/.../engine-parts-camshaft-specifications-1.pdf
or here
https://www.melling.com/wp-content/uploads/2017/.../Cam-Specs-Stock-294-304.pdf
drop them a note
Sorry, I was thinking about the Elgin 426 Street Wedge replacement cam. (E-327-S) 208/210 @.050", .430" lift, 113LSA
I was hoping this SPD-19 was the 300 degree, .520" lift Max Wedge solid cam, .028/.032" lash.
The Elgin or TRW 327 is the universal replacement for the non HP B/RB cam
let's hope it is perhaps you could get a local camgrinder to make a master
I had OREGON Camshafts regrind me a SB 284*/.528 solid PurpleShaft replica off of a RV cam core with a 112* LSA. They also did me a regrind of a 392 Gen1 Hemi core into a Comp Cams 286H (Magnum, .490" lift) with a 109* LSA. I bet they could map the lobes and remaster if there was any interest.
not here either
or here
drop them a note
Any luck with the older Melling catalog? Just trying to get some more details on this camshaft. If it's a solid, I bet it's .028/.032" lash like all the early wedge solids. I really need to V-block it or put it in a block and degree-wheel it.
