joel
MOPAR,ENGINES ---BIG BLOCK,+intakes,heads,383,440-413,+ more -
440 forged steel crank will need turned std. now
75.oo
1965 383 shortblock,, seized from sitting clean,, 6-16-65 250.oo
65 413 block dated 4-2-64 no caps 100.oo
HEADS
452 heads rough cond, 100.oo pr
346 heads may or may not need rebuilt 75.oo pr
INTAKES
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
thermoquad iron intake 20.oo
67-69 440 iron intakes many to choose from 100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
70 440 iron intake #2951736--dated8-23-69 125.oo
72 factory dual plane iron intake#3614014 25.oo
VALVE COVERS -BIG BLOCK
69 440-383 h.p. nice 125.oo pr
71 set 50.oo pr
72 set 100.oo-blaseted primed
many more 25.oo pr
no 70s
water pump housings BIG BLOCK
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--100.oo
big block 4 groove crank pulley for steel crank 40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
BIG BLOCK non h.p exh. manifolds 50.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
located in n.w. penn
edinboro pa 16412
75.oo
HEADS
INTAKES
5-18-68
10-11-67
100.oo
71 set 50.oo pr
many more 25.oo pr
no 70s
edinboro pa 16412
