brian.linn
I picked up a Mopar Performance 426 Hemi that needs the oil passages drilled. Does anyone have a good recommendation to a machine shop who could do this? I am in the midwest. Thanks!
This doesn't have ANY oil passages drilled.I had the same problem. The oil galley on the drivers side was only partially drilled. At the time I lived in Abbotsford B.C. and surprisingly I found a local machine shop to do it so hopefully you won't have any trouble getting it done. It did cost me a few hundred dollars but I didn't care.
