MSD wiring to tach adapter
DynaBro
7:34 AM
Minneapolis
Tach does not work. Red and white wires off tach adapter PN 8920 go to nothing.
White wire off MSD 6A PN 6201 go to nothing.
Any ideas?
And the best coming from the MSD is going nowhere as well.
Maybe some visual aids might be in order here......
Ok so I connected the White to the White, and the Red from the tach adapter to the Gray form the MSD. Nothing. Then I left the Gray bare and connected the Red from the tach adapter to a hot fuse box. Still nothing.
Got it sorted. Tach works and I’m pretty happy. One victory. Tuesday the oil pump is on deck.
Got it sorted how? The answer might help the next guy...
The gray from the MSD went to the white from the tach adapter. I ran the red from the adapter along the firewall to the other side of the engine bay and mated it with two other thick red hot wires mounted to the small lower block left of the master cylinder. I’m hoping that’s the same as splicing it into an ignition wire. Anyway it worked.
