Need 1968 RR fuse box location pics
NGC414
11:56 PM
Ohio
I am putting are car back together I bought disassembled. I just installed the dash and started finishing up the wire harness. I'm not sure exactly where or how the fuse box mounts. I assume its in the glove box area somewhere. If any one has pictures it would be greatly appreciated.
It goes in the left side of the glove box. it mounts at the end with a big phillips screw. The screw is on the bottom side when you mount it. It is up at the end of where the box is so you can get to it after you get it mounted. I don't have any way to post pictures but it is pretty easy to get it where it needs to go. Good Luck! Ronnie
It mounts on the left side of the glove box like said. There is a little door cut in the glove box to gain entrance for checking or replacing fuses. Do you have your glove box yet? If you set it in place, you will see what we are saying. Good luck and if you need more help, just holla.
Thanks for the help & Posting the picture, that answers my question. I do not have the clove box in yet, I ordered it last week. Thanks again.
