Need a favor from a 66-67 owner.
SandDiesel
11:35 PM
SoCal
Need a huge favor if you would. Could one of you give me the bolt hole measurement from your front bench seat? Need the mounting point measurement front to back (poss 11"?) and side to side. I had a seller send me 11" front to back and only 44" across on a 66-67 bench he has. Mine is closer to 50" across so just want to check with you guys. I have a 65 Belvedere II with zero interior and can only find 66-67 benches front and back. Also anyone know if the rear bench from a 66-67 is the same as a 65? Thanks!!!
the 11" and 44" is correct I just measured mine, and I doubt the 65 rear seat is same as 66-67 and the only reason I say so it that nothing else seems to be the same either!
I think 63/64/65 is the same, but not 100%.
There's quite a bit of room between my rocker panels and seat track on my 66.
Thanks guys. I thought maybe the benches were the same width but that's half a foot short. Search goes on.
