ChargerST
I need the precise distance between the block (440) and the face of a 3 ring ATI Super Damper. Block reference should be timing cover/water pump housing attachment face.
Here is a pic (not mine) - is the forward looking oil pump mounting face on the same plane as the timing cover mounting flat? If yes, then it seems the easiest way to measure from the pulley face to the oil pump cover mounting face.
Thanks for your help!
