Need a Mopar man
trim
4:57 AM
midwest
Sorry, duplicate
Not sure this is appropriate here, but certainly the people I might need will be in this forum.
Hi All, Been a while since I've been on, but believe I'm at the right place.
Own a 69 RR 383 4spd numbers matching. Had a little trouble with the lungs and have let the project go for some time. I'm looking for a good Mopar mechanic (for pay) or someone familiar with same. My RR is sitting (approx. 1 yr) without being completed. Need to re-install front end (K-frame, suspension and steering all new from Firm Feel), engine (complete but needs to re-install intake, carb and linkages, steering box (Firm Feel), new disc brakes from Master Brake, steering column, new wire harnesses and basically engine compartment (newly painted) accessories.
The car is not entirely orig..... valve covers, power steering, power disc brakes were not on vin tag.
Need someone in the Kimberling City or Springfield Missouri area and will probably take more than a few days???? Willing to pay at going rate + whatever.
You can message me thru this site and I will send e-mail add
Appreciate any interests, Jim T
PS. I Have most equip. needed. Just missing the body :)
good luck, good to have you back, I hope your healthy now... maybe someone on here closer to you, can walk you thru & help with the stuff... I would if you were allot closer to me...
If you were closer to the iowa border, I would be more then happy to drive down and help you out as i'm off work due to an injury till april 24th.
