soundhd
Have a recently purchased 70 RR. Has power steering. When I bought the car last fall installed a new power steering pump (saginaw), power steering gear box, and both hoses then had the front end aligned.
Here is the problem (and it happens a lot) when either trying to pull out of or into a parking spot when I try to turn the steering wheel to the left after about one-eighth of a turn the steering wheel stops and tries to "bounce" back to the right (not sure how to explain it with a technical term). Really have to force the wheel to turn to be able to get out. Now it does not happen every time but a lot. If I pull the car straight out of a parking spot then turn the wheel it does not happen (that I can recall anyway).
Never happens when driving and only happens when trying to turn the wheel to the left....never to the right.....
Was suggested that I pull out and clean the pressure relief valve which I did yesterday but did not correct the problem.
Was wondering if anyone else has had this problem in the past and what was done to correct it...
thanks
thanks
