old guys rule
Can't seem to find any hose flexible enough to snake into gas tank through filler neck to pump out old gas. Any ideas?
I have a pump. Can't find hoes flexible enough to sneak into the tank. Can't believe this is a problem for me. Whatever you think let me know.hook up an electric pump to the line and pump it out, or add line to the exsisting and hold lower than the car and use gravity
Yes. Where do you mean to hook up to?does car still have a fuel line connected to the tank, that is what i was referring to use
I have a mechanical fuel pump. Have no reasonable answer for why I didn't think of this accepting maybe too many birthdays. LOLfuel line going into mechanical fuel pump from the tank, under the hood would be my first choice but if you have a electric fuel pump, anywhere between there and the carburator with a way to connect a fuel line hose to the electric fuel pump to pump into a can and obviously make sure no leaks and isolate and insulate the connections the fuel pump wires from sparking
That's what I do, disconnect fuel line anywhere you want, then pressurize the tank with a few PSI of air.Heard you can run the fuel supply line into a can, put air nozzle in tank, stuff a rag around it to seal it and blow the air nozzle and the fuel will come out the line.
Emphasis on FEW... otherwise it's balloony tankThat's what I do, disconnect fuel line anywhere you want, then pressurize the tank with a few PSI of air.
Thanks, but don't push it. Not till January 31It's your birthday?
