99ss
Ok I have a painless performance wiring harness and no when I turn the key to start.. I have double checked all the wiring and it was done right far as I can tell... question I have is the yellow wire to the starter relay.. is it hot when the key is on or only when the key is turned forward to ignite the starter?
Is there a steering colum gorund or something I missed..
I dont have the turn signal harness hooked up only the 5 wires for the painless harness.. red blue black yellow brown.. the last three small red (2) and orange wires are connected to anything in the painless harness
no power on eother side of the coil either but the red choke+ wire has juiice
the car started before I put the new harness in. and took out the original ..LOL am I missing a ground somewhere.. the trans saftey is wired to the safety relay correctly.. could the new starter relay be bad? frustrated
