Sleeperbee
Hello resto folks. I've added some components to my 1969 Coronet that aren't original such as Holly Street Avenger carb with electric choke and Delta PAG electric fan. The controller and electric choke need 12 volt juice only when the ignition is on. My fuse box is stock and pretty booked up. I want to run a wire from one remaining accessory blade in the fuse box to a relay that will handle two connections (fan controller and ele choke) - like the relay for the stock two horn wires? Can someone recommend a specific relay item? Its my last item on this build!!! and I can't get over the hump. Thanks
