74Runneer
I yanked the gauge cluster out of my 1974 road runner so that I could test and fix my gas, temp, oil, and batt gauges. I bought a new rte solid state voltage limiter.
This is my test set up. I attached the 12v to the red which goes to the ivr, then the 5v from the ivr goes to the temp, oil and fuel gauge. I then hooked up a resistor (10, 22, 68 ohm) to the opposite peg of the 5v and then grounded it at the ivr and then to the battery. I tried this and all the gauges pegged out. I then tried using a 9v batt instead of a 12 going through the ivr. So I wired the + to the 5v peg and then wired the resistor in and grounded it. I did this with the gas gauge and it worked and the gauge read correctly for each of the resistors. However i did the same set up with the oil gauge and it didn't move at all and I did it for the temp and it read 0, 1/4, and 3/4. Does this mean my oil and temo gauges are shot? I need help, thanks
