Need help
Roger63
4:34 AM
Skiatook ok
I'm working on a hydraulic clutch ,replaced the master cylinder twice. Because it wont pump up, tried reverse bleeding, nothing is working. But when you remove the new master cylinder it squirts all over the damn place.
If it won’t pump up then it’s passing air somewhere. That system is a slave cylinder and a mechanical bearing correct, not a hydraulic throw out bearing correct? Block off the MC and see if it bleeds down.
All correct its driving me nuts
