2quick
Help, I rebuilt my power steering box on the 66 and after installing it back in the car I had problems with the centering valve on the top of the box.
I pulled the valve assembly off and found a tore o-ring but when I installed the block back on the pump and tightened it down I broke the pin and need a replacement.
If anyone has an old worn out box that has a pin in it I would be glad to pay them for it. Don’t need the box just the pin and it can easily be removed, even in the car.
Looking at the top of the box remove the two 1/2 bolts holding down the centering valve block and just lift it off the box, you will see a pin with a mushroom head and slot machined in the top. It will have a spring around it. The pin Just pulls straight out. If anyone is willing to do this it would be greatly appreciated.
