needing
dragrazor
3:10 PM
Iowa
these are the pivot type pieces that go in the hood release lever rod. need two 66 Charger thanks
Hadn't thought about that. When converting to a Charger grille....do I need the Charger hood release?
You might check the Help racks @ napa/oriellys or even Fastenall, I think I've seen similar for lock rods, might not be exact but will "bush the rod".... no pun intended..
..... but we will wait on RC & Poly to add!
I have some very close that were on carb linkages etc. will check on the help rack thanks
mmissle,
no, the 67's have a regular "reach under the front edge of the hood" style. which you could use on a 66 or 67 Coronet as well with a Charger grille for instance. or maybe use what's already there???
