FOR SALE new 360 LA engine stuff
hacksaw
4:38 PM
hopewell PA
Feedback: 1 / 0 / 0
for sale or trade for ???????
new flat top STD alloy 360 pistons on shot peened recon rods and rings and bearings in the box ....375
std 360 truck crank with balencer and flex plate will need cleaned up 175
in south central PA . can deliver with in reson. any questions ... hit me up.
block heads and intake sold
brand or part number for the pistons?
1273 with 000 under that
There is 50 N. Wrist pin hole is steal reinforced..
Silvolite 332 alloy Piston Set, 1273 std 360 71-81​
Engine Family: Mopar Small Block LA
OE Cross Reference: 3549366
Engine Displacement (Liters): 5.9
Engine Displacement (cubic inches): 360
Piston Head Type: Flat
Compression Ratio: 9
Top Land: 0.28
Pin Type: Press
Compression Height IN: 1.576
Top Compression Ring Thickness IN: .0781"
Second Compression Ring Thickness IN: .0781"
Compression Height MM: 40
Oil Ring Thickness IN:
.1875"
Piston Pin Outside Diameter MM: 25
Piston Pin Outside Diameter IN: 0.984
Bore Diameter IN: 4
