Slantsixdan
Three new American-made adjustable vacuum advance pods. $14/ea plus postage from Seattle, Washington, USA. Save $12 by buying all three for $10/ea.
VC-167: Adjustable, arm stamped 9.5 (= 19 crank degrees max advance). Fits any aluminum-body Slant-6 or small-block V8 distributor and works with all breaker plates through '71, plus '72-up plates that have two advance arm pin holes (this pod's arm pin fits the outboard hole)
VC-168: Adjustable, arm stamped 9.5 (= 19 crank degrees max advance). Fits any aluminum-body Slant-6 or small-block V8 distributor and works with all breaker plates through '71, plus '72-up breaker/pickup plates that have two advance arm pin holes (this pod's arm pin fits the outboard hole)
VC-208: Adjustable, arm stamped 11 (= 22 crank degrees max advance). This is the Feather Duster/Dart Lite pod. Fits any aluminum-body Slant-6 or small-block V8 distributor and works with '72-up breaker/pickup plates (this pod's arm pin fits the outboard hole if there are two)
