Sonny
It’s all fun til the rabbit gets the gun.
‘70 Belvedere 440. No ac, stock AM radio, no power windows or seats, mech fuel pump.
All new stock wiring harnesses.
1. I am running 2 12” electric fans pulling about 17 amps each. I’m pulling power straight from the alternator stud to the fans thru breakers and relays. Stock alternator at 65 amps max., but at idle with fans on voltmeter reads 11 or so. Lights on it’s even worse. Back to 12-14 volts cruising.
2. Considering upgrading my alternator to powermaster 95 amp (65 amp at idle). Also going 1 wire alternator and removing Mopar VR and both field wires. Which leads to question #3 below:
3. Should I do “Mad Mod” and upgrade wire from alternator to stater relay to 8 gauge wire? (I already bypassed the ammeter). “Or” with fans powered straight from alternator should I leave stock harness as is and just add alt and remove stock VR?
Thanks!
Thanks!
