Looking at installing a mopar 272 455 cam in a 74 400 engine. Do I need to degree the cam or can I do dot to dot?
Thanks!
Can't believe we are debating this.Do you drop a crank in or throw a set of rods in without checking clearance??
It's a simple task that is worth the 45 min to an hour to double check the cam events.Doesn't matter what HP level the engine is or if it's 4 or 8 cylinder,,,,,,,,,
