Don't know if you have seem my other post where I removed my engine, and discovered that I need a new clutch.
I'm looking around and haven't seen many Borg & Berg options, the one that I'm considering buying is this one:
RAM Powergrip 98504HD CHRYSLER RAM Clutches 98504HD RAM Powergrip HD Clutch Kits | Summit Racing
I was planning to get a new flywheel as well, and was wondering what is the difference between the normal and lightweight version.
normal: 1595 - Steel flywheel Chrysler 6 bolt 143 tooth - RAM Clutches
lw: 1595LW - Lighter weight steel flywheel Chrysler 6 bolt 143 tooth - RAM Clutches
is there any advantage or disavantage?
thanks,
Ed
a833 removal
quick question, should I detach the transmission from the bellhousing first, or detach the trans and bellhousing from the block together? I removed all the bolts but it seem that the trans doesn't want to leave the bellhousing, so I decided to ask first before forcing. Thanks!
www.forbbodiesonly.com
thanks,
Ed
