65belvieToo
New Member
Hello all, mopar man for a long time but looking for some clarification. When looking at b-body parts there seems to be a difference between 62-65 and 66up. Are there chassis diffs?
Thank you Glenwood, i am getting ready to order some header back exhaust components and some makers only supply 66up.About the only things that are constant are the front suspension components except the k frame, idler arm, steering box, etc. The rear end changed in 65 to non tapered axles and remained the same until b bodies changed in 71. Of course 65 is in the middle of the change from cable operated 727s.
Thank you Grady, i will soon!Welcome to FBBO from CT. If I don't ask, someone else will - got any photos of your ride(s)?
The kframe is about 1.5-2" closr to the firewall on 66-70 I believe. This leaves you more room on a 65 but then issues pop up with power steering box clearance with some header brands.
Welcome aboard to FBBO btw.
