New Hinges - How to Paint?
EngineerDoug
2:17 PM
Los Gatos, CA
Hello folks,
I have a set of new door hinges that bear a rough but shiny finish - I suspect they are plated (zinc?). I think they are from AMD. My question is, will this finish take primer and paint OK? Or do these need to be treated in some way before the primer/paint will have enough "tooth" to properly bond?
Thanks.
Scuff with red scuff pad, Degrease, Spray with etching primer, then straight to color
I agree. Zinc can sometimes cause adhesion problems, so make SURE to scuff it well & you should be fine. Door hinges don't take too much abuse. And don't forget the etching primer, just like Mike says.
