70GETEX
Hey guys, I installed a new M&H engine wiring harness for my 440 GTX on Saturday. This is the one that is modified for electronic ignition. I removed the old harness which worked fine but had some questionalble wires & hacks on it. I then installed the new harness which looks wonderful. When I fired the car up it ran but it ran like the distributor was retarded a bunch, no power. The car already was setup for electronic ignition and had the ECU and the correct alternator. I added the newer 4 pin ballast resistor and made sure I had the wires connected correctly on the ballast for the correct resistance. I got frustrated and put the old harness back on and it ran perfect once again. I ohmed out the new harness and it appears to be correct? Any ideas?
