Gene C
I have a new never started 471 stroker engine, all good stuff! Manley 5.535 rods, 440 steel crank cut to fit 400 block. 990 rods BBChevy size King racing rod bearings, Clevite mains Std. Ross pistons 749.00 super lite 520 grams over 12lbs taken off rotating assembly. Should rev like a small block 906 milled fully, nicely ported flow 300@600 lift exhaust over 200. Like a F.A.S.T. head Factory appearing Stock Tires 9.83 on G70/14 polyglass tires!!!
New Race Demon 925 carb M-1 intake 7qt pan hemi size oil pick up, over 9540.00 dollars in parts!!! Machine work done by the best in NYC area - Ace Crankshaft. They do all types, race engines only. Leaving cam choise to buyer hydraulic about 575-590 HP with 120lb springs or a 600 lift solid cam that would make 600-625 hp +700.00 for solid roller or +535.00 for hyd roller Springs and pushrods. Don't recommend solid roller unless small street roller as I wouldn't go over 750hp. Can pull just as much HP from solid lifter or hyd roller. Hyd flat will make as much as small 523,557 purple solid cams solid 590-600 type cam will get up to 640hp no problem.
Can vary compression from 10-1 to 10-8 to one with...023 steel shim to cometic 053 head gasket from 78cc to 86cc 8cc difference comes with EVERTHING... aluminum blk and silver dir connection Valve covers, carb, msd 6al, distibutor rev limiter, aluminum water pump with electric drive, 230.00 MSD coil, billet timing chain, HV oil pump block deburred, two race oil filters cam additive 7 qt. break in oil, 2 sets plugs ,Mopar race and autolights fuel pump, new billet oil pump drive SFI damper with billet lower pulley msd or Moroso ultra 40 wires.
This thing is worth over $12,000.00 all the extras, oil plug filters additive special oil v/c, water pump wires, race carb. Selling for less than price of parts asking 9500.00 dollars offers considered. Please e-mail w/any questions.
