Phil Anderson
Just replaced my oil pan with a new correct one from Schumacher. I also purchased the carbon fiber combination windage tray gasket package from JEGS. This is a one piece design. You dont put any gasket sealer on it and it is reusable. My question would be this. I purchased a timing cover gasket set . It came with a large piece of cork gasket that appears it could fit if you trim it. I installed the Jegs Gasket tray and did not use the extra piece of pan gasket. Everything looked good. I took a feeler gauge and ran it around the front of the pan under and between the pan and the bottom of the timing cover. everything appears to be good. What was the extra piece of pan gasket for ? It just doesnt seem to fit anywhere so I did not use it.
