WELL,,,,THOSE OF YOU THAT HAVE BEEN FOLLOWING THE CONTINUING SAGA OF THE PIPES....i just got the Road Runner back with the new exhaust. i must say it is a work of art! 2-1/2 from the manifolds to the flow master 40's... and 2-1/4 the rest of the way. perfectly bent and everything is centered. i had an "H" pipe put in to level out the sound. it sounds exactly how i envisioned (....envisioned???)...ANYWAY. you know what i mean.
idles rumbly....highway is nice.... only thing i can say is a bit annoying is there is a drone at 1900 to 2000 rpm...then it goes away, other than that i couldnt be happier and i didnt have to spend a grand or better on an "accurate exhaust"...and lay on my back for 2 hours! They did the complete job for $600.00 and i never seen welds look like blown glass . NICEEEEEEEEEEEEEE.
i did notice its running about 20 degrees cooler also....and has a little more "giddy-up" should the flow of the exhaust affect the running temperature like that?
