Trashdog67
My freshly rebuilt '67 318 has no compression in 5 of the cylinders! Only cylinders 2, 4 and 6 show compression and it isn't but 60 psi.
This engine had about 33,000 miles on it when placed in storage about 15 years ago. Recently I had the block bored first over, crank was good as is, and the heads were treated to hardened seats, new valves and springs. When I assembled it I was careful to install the cam drive properly. At least, that's how I remember it. Human factors studies say this may be wishful thinking. With the damper timing mark on 0 degrees both pushrods of #1 cylinder can be rotated with finger pressure.
Can I get some opinions as to wether the cam timing could cause the problem or maybe pushrod length is too long.
I have had the engine running by the way. It has a definate shudder at low rpm.
Can anyone help?!
Can anyone help?!
