Dominic Torreto
Had everything figured out on car every damn thing worked. Took it on test drive speedometer wasnt working and it used to work in 2012. No big deal because I knew how to fix it. Only problem is the voltage meter wires grounded the dash amd it smoked a ground wire. No power anywhere but to the starter. No power from the starter to the starter relay. Changed both of those and still nothing. I did run power straight to fuse box and everything worked directly. I dont know whats going on here guys please explain.
