Mopar electronic ignition sorry.
Yes, I'm well aware; means nothing in my case, however.
Are you actually reading what I've been posting?
I'll try one last time...
My '68 GTX had the ignition system replaced by the previous owner with a factory setup from an
early 70's 440 electronic ignition. Wiring, ballast, distributor, voltage regulator - the whole bit.
It has a dual ballast included in all that, but only needs the single one (other leg was never used).
I'm currently running a Blaster II coil, older MP orange box and a ballast of around 0.4ohm.
I have the original Chrysler distributor from the swap, along with a new one (A1/Cordone I believe)
and an MP one that I can swap out as needed.
The coil is showing signs of leaking around the crown, so it's gotta go.
So....
The question remains - is the
stock coil in the original factory electronic ignition of the day the same one
as the
stock coil in the late 60's points-style ignitions?
Are the
stock ballasts the same as well?
