TKMSavoy
This concerns by 1962 Plymouth Savoy. Four-door 318/727. The car has been in the family since new I have been the sole owner and caretaker For the last 45 years. She has slowly been developing a mild vibration on acceleration, close to a shuddering, that disappears around 15 to 17 mph. Between 37 and 52 miles an hour it develops a vibration/low frequency drone that then disappears. The shuddering at low speed and the drone at higher speed both immediately disappear if I lift the accelerator or put the car in neutral. I have run the car up to 85 miles an hour and there’s no further vibrations or drones beyond 52 mph.
The transmission has been recently rebuilt (Thanks DVW, the trans is like new). The drive shaft has been removed, the ball and trunnion joint has been rebuilt and the U joint has been replaced. The single balancing weight on the driveshaft is in place as it has always been. I had the differential serviced at a shop that deals only in differentials, and there are no issues to be found. Contact points were perfect. The lash was as it should be. The rear wheel bearings were slightly dry and regreased. Otherwise, no issues with the differential.
No, the story gets a little more interesting. Wondering if it was the pinion angle, I loaded approximately 200 pounds in the trunk and had my wife sit in the backseat and things changed. The shuttering at acceleration low speed became noticeably more prominent and yet at the same time, the vibration/drone between 37 and 52 mph completely disappeared. I mean completely. Would love to hear your thoughts on this. My instinct is to shim the rear end to change the pinion angle. It’s so I don’t know which direction it should be ashamed and also wondering what size shims to start with. Of course I recognize my limited skills and I could be completely wrong, but my research is pointing in this direction. I checked the angle of the differential drive shaft and transmission. Found the following. Differential up 1.2° trans down 1.5° centerline of the driveshaft 2.5°. I don’t think I missed anything. What do you all think??
