The days of carrying jumper cables are over. This small light-weight power supply will pack a punch to start the weakest of batteries. This is a must have for any car enthusiast, especially if you store your car away from home. There is no longer a need to worry about picking your car up from storage and being surprised by a dead battery. Not only can you jump start your car but you can recharge your phone and other devices such as iPads or tablets.
Lithium-ion technology means longer life for the battery. Holds a charge up to 6 months without recharging
Cold crank a car up to 20 times
Built-in LED flashlight. Uses energy efficient LED bulb with light modes: standard work light, strobe and SOS
USB port with pigtail adapters, wall charger, auto charger, smart jump cables and zippered compact storage case
Multi-functional Jump Starter Specs:
Battery Capacity: 35.52Wh Start Current: 200A Peak Current: 400A
Input: 14V/1A
Output: 5V/2A, 12V for jump start
Charging Time: 3.5hrs
Life Time: >800 cycles
Size: 180 x 87 x 29mm
Weight: 445g
Operating Temp: -20°C~60°C/-4°F~140°F
