October door hinge rebuild special!!!!
res1vw21
11:03 AM
seattle
For the first 20 people in the month of October I am going to run a 10% off* special on door hinges for:
A body
66-70 b body
E body
F body
* does not apply to core charge.
Get them in quick before the 20 spots get filled up!!!
As some of you know I rebuild door hinges for people, recently I have had to change my methods a little due to parts supply but it is for the best because now they are stronger and better then ever before!
Pricing is as follows for any standard mopar: A,B,E,F
$70 a side (top and bottom) or $130 both sides (top and bottom) + $15 shipping for the return ride. $50 core charge will be added if bought outright.
What you get for your money:
Media blasted clean
Epoxy primer in gray or left bare
New pins in all hinges
New brass bushings on both top hinges (except F which gets new pins)
Star wheels removed, repaired and reinstalled
New wave washers installed
Springs repaired
Assembled and and sent back to you labeled for position
The reason they are not greased is so you can paint them to match your car then use a spray lube type grease for long life.
Paypal only for the special
Thanks a bunch
-Ross-
Click for pics!
http://www.forabodiesonly.com/mopar/...02#post1256402
Pm's replied again! Thanks guys this is going to be a nice batch this month!
Two nice sets of b body hinges about to head back to their owners!
PM'd you. But I am looking to buy a set of 73-74 B-Body hinges, outright if you've got em.
