I think welding the nut on the hanger and drilling a hole for it is my best bet. I hate drill holes in the frame tho.. Thanks
I was thinking about that also, That seems like a very good way. I have US Car Tool boxes also, I want to tac them on is why I'm trying to get this stuff in that area right, now. Thnx guys!I'm going to drill through the frame using the hanger for a guide weld in a tube and get a bolt to go all the way through. Should be solid as a rock and frame will be sealed back up.
I put US Car Tool torque boxes on also, see 69 GTX on members projects.
They are 1/8", or .130.What is the thickness of the reinforcing plate, please?
Got one side fixed up. Will do the other tomorrow. Welded the reinforcing plates also.
Nothing to see on the other side. As in your 1st suggestion, I welded the nut on the side of the hanger, used my die grinder to minimize it's size then drilled a hole in the frame rail for it to fit in. I figured welding the hanger to the rail does 2 things, 1-gives the hanger more strength and 2-makes the rail even stronger than before I drilled the hole. The hanger metal is much thicker than the frame. And I put the welds where they can be easily cut off in case the hanger ever needs to come back off, which I doubt it ever will.They're not going anyplace Dakota Kid . . . looks great ! !
How about a pic from the other side of the frame rail ? ?
Like to see how you finished it up too . . . Thanks ! !
The offset kit comes with offset shackles also, as you can kinda see on the left in that last pic..What did you do for the rear shackles?
Thanks for your help!
