PurpleBeeper
70 Roadrunner 440 with a Milodon "hemi" pan & matching Milodon 1/2" oil pickup tube (I think this is a repro of a 71 hemi e-body pan), running stock windage tray. Old school Direct Connection chrome timing chain cover w/paper gasket & running cork oil pan gaskets. Hughes rear main seal cap w/silicone seal, cocked 1/16"-1/8" to one side & one drop of glue on ends w/silicone side seals. It looks like the oil is leaking out of the passenger side-rail area of the block/pan surface and "possibly" up by the timing cover. The oil leak is definitely more prominent on the passenger side as it sits now. This is a good size leak and I'm going through a quart of oil in 100 miles....1/2 quart in about 20 miles. I've got 7 quarts in the motor (6 quart pan + one quart for new filter being installed).
1. I've had a ton of oil leak issues on the bottom end since getting the motor back in this car (2-3 yrs).
2. Changed pan gaskets & rear main seal twice. Back of rear main seal was bone dry both times, so I'm pretty confident I don't have a rear main seal leak.
3. Since I have hardware store bolts in it, I thought maybe the pan bolts were bottoming out & I changed 1" bolts for 3/4" bolts.
4. I got lazy/frustrated and took it to a local shop. I gave them a brand new Milodon pan, cork Felpro gaskets, 7qts. oil/filter.
Guess what? Still bleeding oil all over the road in basically the same place. I'd over-torqued the OLD pan bolts and distorted the lip somewhat, but this is an identical NEW pan. The new pan came with a set of bolts and I believe they used most of the new ones. All I can think of is 1. Some bolts are still bottoming out...either I need 1/2" long bolts and/or there's a bunch of RTV or rust up in some of those holes.....so some bolts are still bottoming out and aren't really tight. 2. Somehow the cast iron on the bottom of the block is warped...and I didn't think that was possible. I'm so confused. Any/all ideas appreciated.
