moparjohnny
The tail shaft how many shift mounts?b body or a body
The pre 70 transmission will have one mount and that will be close to the case. The 70 and newer will have both but none will have only the rearward mount but sounds like you might have an 'A' body transmission with the shorter tail shaft? You can swap out the tail shaft on that for the longer TS....can i replace that tail shaft with a one mount closer to case shaft?
