Yeah, it was actually in the kit I used to press it in. It was actually easy to press in! ahhahaa....damnit... I got the kit again and I'm going to put the socket on it. I believe the torque specs are 125 ft/lbs. If I can torque it to that spec and it holds, I'm going to leave it alone. To be honest with you, I think it will be okay. I got lucky this time... poor upper control arm. I've had 4 vintage mopars, and have built 2 small blocks, and 1 big block, but I have little experience with there front ends. I've never changed torsion bars, I've never pulled the lower control arms. I've done tie rods, pitman arms and centerlinks. I just really screwed up this upper control arm. I guess I should think about it like this: In all, I've done WAY more good for this car than bad!
