mferraro76
Currently in the works: 318, bored .030 over, stock cast crank, stock rods, forged pistons. I am looking for a weekend driver with some snot. I was thinking about supercharging but the CR is prob gonna be too high (9.5:1 est) and i'll likely do a separate build specifically for that later.
i am thinking about adding the RHS heads and the RPM air gap intake. currently i have a 625 cfm carter, i could go bigger if needed. i can't decide if i should keep my current cam (purple shaft 284/284 dur, 484/484 lift, 108 centerline, 241/241 @ .050) or step down to something in the 1500-6000 range.
So, am i tapping into the capabilities of this block or am i using the wrong combinations?
also, would there be benefit to a better oil pan, windage tray, or other goodies while this thing is apart?
(other misc info: 3.23 rear, 68 sattelite, will prob use tti headers, already have mopar electronic ignition and would like to reuse, have beefed up 727)
