FOR SALE Original 1972 B-body Tilt Steering Column
QuickBpBp
10:39 PM
SE PA
Feedback: 109 / 0 / 0
Here is a Rare Original '72 b-body Tilt Column. It's tilt feature works nice and appears to have all wiring which will need gone over as I see an overheated wire in the terminal block. Steering wheel is there but would need a major restoration.. Missing the shift lever and the PRND21 bezel/light assembly.. Would be a neat up grade and not a non stock looking $1,000 aftermarket unit. $350 OBO plus shipping but would prefer pick-up...
Parts are located in SE PA.
Can send more pictures if interested.
Pm here on the board.
Thanks for free ad FBBO!
Hi, do you know if can u change the column to a floor shift column. With buying the new piece. Also can you put a different sterring wheel on it. But doing a 4 spd car.
Could not tell you but I have seen people take an auto on the column and just cut off the lever in the pot metal and do body work smoothing it out...This would need some more work due to the "PRND21" area needing smoothed out. I believe you must use a similar "flat" rim blow steering wheel.. I believe P & D C-bodies with tilt all used the same steering wheel which would be a good source..
Thanks for the info. I'm going to check out more to make sure it will work. Thanks Paul
