FOR SALE Parting '64 Polara 500
Rolling Thunder
7:36 PM
Trenton, IL
Parting a '64 Polara 500. I'll be using all driveline but most of rest will be up for grabs. Excellent outer trim.
Message me with needs and I'll let know if available and price.
Located outside of St Louis MO.
Is the upper and lower cowl any good ? Thanks
Upper looks good but won't really be able to tell till pull fenders later.
Please let me know as I can use what is still good I assume it's the same as 65 coronet ? Let me know when you get to it happy new year
Hey Rolling, did you get my private message?
I'm looking for the hood trim that goes across the front of the hood. Maybe entire hood. Thanks.
Hello Rolling Thunder,
I'm looking for the folling parts for my 64 Polara 500:
  1. The push button shift delete cover on the far left of my dash. It is mounted with three small screws. Mine has a hole in it for possibly a switch of some sort. I want to replace the cover.
  2. A center console 4 speed top plate. My Ploara is an automatic, being a console shift as it is a Polara 500. I'm thinking about converting to a 4 speed (console shift).
  3. Passenger side (right) front fender.
  4. Left side engine turned door trim.
I read your profile.
I want to thank you for your service to our great country. I am hoping and praying your personal business you and your son have started is blessed with much succes.
Thank you,
Mike
Sorry for the delay in responding. Cars still outside and won't be tearing apart till weather breaks and make some room inside garage.
Is that a 4 speed car? I'm in need of a console 4speed shifter. Thanks!
