1969 beep beep
I have a question about my 69 Roadrunner.
When I lock the drivers door from the inside and pull the interior door lever the door unlocks. When I do the same on the passenger side the door it won’t unlock. It only unlocks from pulling up on the lock button. Is this normal? Can some please check on there car.
Maybe it’s normal not sure. Both doors locks work great and both have the safety key lockout from the outside. Meaning you can’t lock the door unless you use the key from the outside.
