Pictures needed of fire wall where vacuum line inters for n96 ram charger hood
al71
8:57 AM
Boise
Does anyone have pictures where vacuum line from ram charger hood goes threw firewall to vacuum dash switch on original n96 car please
Here is an old thread of mine. Now, this is for a 1970 Road Runner, so I don't know if yours is the same or not.
Look at post 37, but then scroll through a bit. The bottom line is that on a 1970 Plymouth Road Runner, some N96 cars had a dimple punched out for the vacuum hoses to route through. Others, like mine, had them routing more through the center. I am unsure of the reason for the differences. It may have been early vs. late cars - who knows. There are a few pictures on pages 3 and 4 as well.
Hope this helps...
http://www.forbbodiesonly.com/mopar...lp-quot-decoding-quot-a-1970-Roadrunner/page2
This is the actual connection for the air grabber vacuum hoses as observed from inside the car just above the heater box. The rubber grommet that has 3 hoses in it is the part that actually seals against the fire wall.
DSC03493.JPGThis is the actual connection for the air grabber vacuum hoses as observed from inside the car just above the heater box. The rubber grommet that has 3 hoses in it is the part that actually seals against the fire wall.
The actual hole in the firewall is right on the seam between the upper and lower cowling halves. In this picture it is just left (about 6 inches) of the silver colored voltage regulator and at a 2 o'clock position above the heater blower motor. There is an old yellowed wiring harness mount just above it. Hope this helps
This is for a 71-72 year car.
sorry for the messed up posting. As soon as I submitted the picture it looks like hsorman was helping you too !!!! His post went in between my two pictures.
oops!!! I need picture of a 1971 dodge charger firewall sorry
