Please be careful out there.
aldal
12:09 PM
Al's World
A buddy of mine whom I have known for 27 years and who by the way had a great shop and was the safest guy I know was working on his car up on jack stands and somehow the car fell on him and crushed him to death. I guess my point is please be safe and take the time to cover all safety aspects of your task. Thanks for reading, Al
That is so sad, very sorry to hear that. I know I am going to be thinking double safety, my whole car has been up on jacks for months. Thank you for posting.
Sorry for the loss of your friend.
Wow, sorry to hear this and my condolences to you and his family. And thanks for the message.
Thank you for your message and a reminder to use that can always use it. Sorry for your loss. 27 years is a long time to have a friend.
Good advice. It is tempting to take shortcuts with the jack and not use the stands when just going under for a "minute.
My condolences as well . . . only goes to show you can't be TOO SAFE . . .
I'll be double /triple checking my jack stands again . . . thanks for the reminder.
Wow, sorry to hear about that. There are times when I am under a car on jack stands and I have any doubt about anything slipping I will put something under the car like an old wheel or a floor jack as a safety precaution. My condolences go out to you and the family.
Sorry to hear this, and it just hit home as well, I just recently changed the rack-n-pinion and tie rod ends on my wife's mustang, I ran it up on ramps, chalked the rear wheel, and proceeded to remove all the bolts and lines to the rack and loosen the tie rod jam nuts, last item left, was the tie rods themselves, and needed to remove the wheels for this part, jacked up the passenger wheel, secured with a jack stand after removing the ramp out of the way, removed the wheel and tie rod, went to the drivers side, jacked it up, removed the ramp, placed a jack stand underneath, proceeded to loosen the nut on the tie rod to the spindle, and pulled the car off off everything towards me, I jumped back approx 3 feet, the car came down to about within 4" from the concrete...I was less than a minute from getting under the car.................................I re-jacked up the car and secured it, had to go into the house for about a half hour to reflect and regain my nerve to get under the car, first time in 30+ years of working on cars, I almost always always always-and had to say almost because this is the first time I didn't, was to slide the removed wheels under the car just behind the wheel well to prevent the car from dropping very far should this happen, don't know why I didn't this time, but had it fallen while I was underneath, the wheels would have prevented me from being crushed, so, it's never too late to be reminded about safety, again, sorry for the loss and and prayers to the family.
A word of safety when using ramps. Years ago i had my brothers olds 88 on a pair of ramps. The old stamped steel ones that did not have the safety braces on them. Went inside to grab a cold beer,came back out and the car was sitting flat on the ground. I would have been crushed. So make sure your ramps have a safety brace on them. Sorry to hear about your friend may he rest in peace.
That's really sad. Condolences to his family. For what this is worth Id like to pass this on to everyone in the interest of safety. I was working on my t-bucket up on jackstands. They were small size jackstands. Not much room under a t-bucket. I was tightening a bolt and when I pulled on the wrench I saw the car move. I almost pulled the car off on top of me just by tightening the bolt! I usually leave the jack under the rear end also just for added safety but it would have been in my way so I took it out. ( As a side note, if you have ever been to an nhra cacklefest they REQUIRE not only jackstands but also the floor jack under the rear end when starting cacklefest cars in the pits. ) So when you are going to be working under your car please use the jackstands with a big base and leave the floor jack under the car and do everything you can to prevent pulling the car off the stands. Chalk wheels too. Believe me you will be glad you took the time to use the extra safety equipment. I know I was. Be safe! Bill
If you are working around cars a lot like most of us are, you get into kind of a routine or comfort zone that can be dangerous. After being under a car on jackstands hundreds of times you tend to get a little complacent and it only takes one mistake to end up seriously injured or worse.
Once I get a car up on jackstands I like to go to one corner of the car and give it a good sideways push and then do the same from the opposite corner. I also leave the floorjack under the car if I can. Just a few of the many things I learned from my uncle about safely working in the shop.
On the same subject, I see a lot of jackstands and other lifting equipment in places like Harbor Freight that look kind of iffy to me. I'd spend a few extra bucks and buy the larger heavy duty stands like Hein Werner or OTC. I won't trust my life to cheap jacking equipment.
And watch out with the fireworks.
I would like to know the details. Not that I'm morbid. But from an inquiring of safety standpoint.
When I we started my son's Charger project, I bought 12 ton jack stands.
I wanted the car up higher than I could trust my 6 ton ones. (Red in the picture).
I like safety overkill.
Looks like they have changed the color and the 12 ton ones happen to be on sale this weekend. They are pretty beefy. Now I'll have to see what else is available.
Don't they ALL come from China anyway?
http://www.harborfreight.com/automotive-motorcycle/jack-stands/12-ton-jack-stands-34924.html
Safety is no accident.
That sucks,
My deepest heartfelt condolences goes out to you his family & friends, for your loss...
