Evan Frucht
Hi I have an Poly 318 engine.
- The camshaft has a mild regrind from PO (based on what he told me, I can tell it has more cam than stock but the specs are unknown.)
- The car has a 2.5 inch dual exhaust with X pipe attached to the stock manifolds.
- Factory 4 barrel cast iron intake
- Later model Carter AFB 650
- Stock points ignition.
- NGK V-Power XR5 spark plugs ... MSD red wires
The engine recently started misfiring randomly and under load. It didnt feel right. I've been trouble shooting the last few days checking various things.
Then today it wouldnt start. I must have screwed up because when I pulled the top off the carb now one of my metering rods is bent I think it was causing the engine to flood. Hence the no start.
Anyways I'm trying to atleast get the engine started so I can finish adressing my tuning gremlins.
I figure this would be a good time to evaluate my current jetting since I need a replacement metering rod. The car has always ran OK with the jetting it came with, but I want to get it better if I can. I have never actually changed or even evaluated the jetting, the PO did it and it always run fine so I didnt mess with it, but i think it could be better and I dont fully trust the random guy who sold me the car... lol
Basically I'm wondering what size main jet and metering rod I might need. The old one is numbered 7147. The main jet says 400 and the other jet says 375. Would it be easier just to change the metering rod right? How often do main jets "wear out?"
Heres the plugs that I've been running for about a year. You can kinda see the numbers next to them. First picture... from top 1,3,5,7. Second pic 2,4,6,8. Third pic is number 7 which looked the worst to me but what do I know.
What do they say about my jetting and/or plug temp? A bit to rich? Other than the number 7 they are not covered in carbon deposits. They are a dark brown blackish color tho.
