TexasStroker
Kind of throwing this out at work...so bare with me if it is sporadic...
I've got an 8AN fitting coming out of the sump...I ultimately want it reduced down to 3/8" line or NPT etc...
I would prefer black anodized fittings.
Does anyone know of a 90 degree 8AN fitting that reduces to 3/8 NPT or 3/8 Barb?? Again, black would be the sinister color of choice (picky, I know, but this needs to look right...not like some mix n match rainbow).
The cell's fitting is an -8AN male thread...I just found a blue anodized fitting that is -8 Female to 3/8" NPT male...Problem is, $30 frickin dollars!!!
Is there a better way to go about this?
Am I better off to run an 8AN to 6AN reducer right off the cell's fitting, then follow it with a simple and affordable -6AN to 3/8" barb or 3/8" NPT??
Or is it better to run an 8AN 90 degree fitting, some -8 hose, and then deal with reducing it later?
This is a 15 gallon cell, 2" sump...I'll have an electric fuel pump (most likely candidates are 3/8" NPT or my old one, 3/8" barb). It will be feeding a mild 440, but hopefully a stroker at some point (hence me sizing it for down the road).
I am also likely to replace my stock fuel lines with 3/8"...And on yet another likely quest to dissapoint myself, anyone know of some 3/8" SS lines...coated in black???
Just trust me on the black thing...It'll look killer if I can set it up like I'm wanting too
