I've had experience with stock pinky finger little effort power steering, slightly more, and slightly more still. Here's my feedback breakdown in terms of specs, feel, and handling
Pinky finger loosest feel -
Car: '67 Impala
Steering wheel: 16-inch diameter (larger wheel means lower effort)
Stock small diameter power steering pump pulley (since this is spinning and driven by the belt, smaller pulley means lower effort)
Feel: Loose as can be. Comfortable to drive, but lots of play in wheel and difficult to correct oversteer quickly. Tough to feel the road.
Slightly firmer feel:
Car: '68 Plymouth Satellite
Steering wheel: 13.5" diameter
Feel: A bit sloppy, but firmer than the Impala. Small steering wheel firms things up a bit.
Still slightly firmer feel:
Car: '68 Plymouth Satellite (same as above)
Steering wheel: 15" diameter
Steering shaft to steering box U-joint coupling swapped in to replace stock rag joint
Upgraded steering gear box to Firm Feel stage 2
Feel: Firmest yet, but not as firm as with the 13.5" steering wheel. Not sloppy at all. A bit too heavy in feel. I am also swapping my small block motor out for a big block and the OEM power steering pump I found has a larger pulley on it (meaning, it will feel firmer than now). This feels OK in steering at highway speeds, but around town from 0 - 40 it feels a bit heavy for my taste. I'm considering swapping out the Firm Feel steering gear box from the stage 2 unit to the stage 1, especially since my new pump will have the larger pulley.
Please note: The stage 1 unit from Firm Feel is not a stock feel OEM replacement. (I made that mistake). It states on their website that it's a bit firmer than an OEM police steering box. I think this will get me closer to the feel I'm after.
I imagine that a full manual steering would feel at least as firm as what I have now, but not as firm as rack-and-pinion.
Anybody else have feedback after installing steering box from Firm Feel? Anyone have a slightly used stage 1 unit from them that they'd like to trade for my stage 2 that has less than 1000 miles on it?
